Flash Sony hvl-f60 - Godox receiver X1r-s.
Forum Name: Lighting
Forum Description: For discussion of flashes, strobes and continuous lights
URL: https://www.dyxum.com/dforum/forum_posts.asp?TID=137435
Printed Date: 12 July 2020 at 05:08
Topic: Flash Sony hvl-f60 - Godox receiver X1r-s.
Posted By: javimoya
Subject: Flash Sony hvl-f60 - Godox receiver X1r-s.
Date Posted: 27 November 2019 at 19:37
Hi Dyxumers,
Today I have received a Godox X1r-s. The flash works perfectly in TTL mode with godox transmitter and received. I change the power but only in TTL mode. So Can I use sony flash manually? I mean to use it like godox flashes. Watching change the power on the flash screen.
Thanks in advance.
a99 a850 M28Rs M35 1.4 Flekt 35 2.4 50ZA 85ZA 135ZA 135STF M17-35G 24-70ZA M70-210f4 S105 OS Macro 70-200G 70-400G II
http://www.javimoyafotografia.es/ - Mi portfolio
Date Posted: 27 November 2019 at 20:03
Originally posted by javimoya javimoya wrote:
... Can I use sony flash manually? I mean to use it like godox flashes. Watching change the power on the flash screen.
You can manually change the power level of the F60M by using the controls on the back of it.
http://thesybersite.com -
Posted By: javimoya
Date Posted: 27 November 2019 at 20:16
I know but I meant to change power level from godox transmitter.
Date Posted: 27 November 2019 at 20:30
The user manuals for the X1T-S and the XPro-S say you can do that. Which do you own, and have you checked the manual?
Posted By: javimoya
Date Posted: 27 November 2019 at 20:37
I have X1TS which controls godox flashes perfectly but not F60 in manual mode using godox transmitter. Only TTL mode. I checked the manual many times with no results.
Posted By: javimoya
Date Posted: 27 November 2019 at 20:59
Godox X1R-S Overview from B&H Photo:
X1R-S TTL Wireless Flash Trigger Receiver from Godox. This 2.4 GHz system is compatible with Sony cameras and flashes that support ADI / P-TTL for automatic exposure and metering
Definitely resolved.
