Nikon D750 and studio flash.
Forum Name: Lighting
Forum Description: For discussion of flashes, strobes and continuous lights
URL: https://www.dyxum.com/dforum/forum_posts.asp?TID=137722
Printed Date: 10 July 2020 at 23:50
Topic: Nikon D750 and studio flash.
Posted By: BenHer
Subject: Nikon D750 and studio flash.
Date Posted: 08 February 2020 at 19:30
Has anyone a good solution to how to connect my studio flashes to my camera. They use a ´PC´ plug. Up until now I have been using the built in flash to trigger the studio flashes via their built in ´photocell´. I don´t mind that I have to set the exposure manually.
I know there are a few ´hot shoe´ adapters available, i.e. the Metz TSC20, with a PC socket, but I am a bit scared to connect the studio flash trigger circuit to the electronics of the camera. I have read the modern DSLR is sensitive to high voltage from the flash trigger circuits.
Any suggestions?
Bengt H
Date Posted: 08 February 2020 at 20:58
Welcome to Dyxum. Probably the best suggestion for your problem is to ask the question on a Nikon forum. Dyxum is a forum for Sony (and Minolta) cameras and while we have a few members using multiple systems my guess is you won't get a lot of responses here.
Date Posted: 08 February 2020 at 21:13
Welcome!
Have you checked the manual for the studio flash (on-line if necessary)?
Between that and the manual for the D750 you ought to be able to get some idea.
Not sure what you mean by a PC plug - do you mean a micro USB?
ANyway, there are some reosurces on the web, such as https://www.flickr.com/groups/d750strobist/ - this one which seems to cover the area you are interested in.
Miranda F & Sensorex, Sony A58, Nex-6, Dynax 4, 5, 60, 500si/600si/700si/800si, various Sony & Minolta lenses, several Tamrons, lots of MF primes and *far* too many old film cameras . . .
Posted By: Michael Johansson
Date Posted: 08 February 2020 at 21:25
If you are afraid of connecting the flashcord to the PC-plug un yor camera there is always the radio triggers to consider. Of course you probably also need a receiver connected to the flas as well as the transmitter on the camera.
(The PC-plug is the round connector that you find on old large format lenses and every old SLR as well as some new cameras often used in studios and the Sony a7R iv.)
a7RII ~ V5.6/10mm ~ V4.5/15mm ~ S1.8/20mm ~ S4/24-105mm ~ V1.4/35mm ~ CZ1.8/55mm ~ V2/65mm ~ S2.8/90mmMacro ~ S1.8/135mm ~ 5600HS(D) ~ HVL43AM ~ Ring+Macro TwinFlash
Posted By: BenHer
Date Posted: 09 February 2020 at 13:31
Hi thank you for a prompt reply.
The ´PC contact´ I was referring to is the old traditional coaxial plug used to syncronize an external flash to the camera. This was designed in the 1930s for purely mechanical contacts and they are not sensitive to the applied voltage or current.
In modern digital cameras however, except some professional ones, the PC contact is not implemented and a model specific modern ´hot shoe´ is used.
My concern is to avoid connecting an unknown, and maybe dangerously high, ´trigger voltage´ to my DSLR.
I know there are many IR- and radiobased remote flashtriggers, but the cost is rather high considering my infrequent use.
Bengt H
Date Posted: 09 February 2020 at 17:38
You could probably test that yourself with a multimeter, connect the leads to the PC sync cable and test fire the strobe and look at the voltage, anything less than 5v will be safe to use.
Date Posted: 09 February 2020 at 19:44
I'm not sure what your budget is or what you consider expensive , but wireless triggers only cost about £15 .
These are dumb triggers not TTL compatible .
But if your triggering via a PC sync socket I presume your exposing manually anyway ?
One trigger that goes on your hotshoe and a couple of receivers would likely do you .
The receivers can be used with either an off camera flash via the shoe or with the supplied PC sync lead plugged into the studio flash .
For eg ; https://www.ebay.co.uk/itm/143414224184 - https://www.ebay.co.uk/itm/143414224184 for £13.70 .
Trigger and two receivers .
I've been using a set of these things for years for both film cameras and digital .
Very simple to use , just plug and play .
Even used with lights of low trigger voltage they make more sense than messing around with long cables .
