(Entries) DPC #304: "Symmetry"
Forum Name: Dyxum Contests
Forum Description: Dyxum photographic contests
URL: https://www.dyxum.com/dforum/forum_posts.asp?TID=141378
Printed Date: 27 January 2023 at 01:49
Topic: (Entries) DPC #304: "Symmetry"
Subject: (Entries) DPC #304: "Symmetry"
Date Posted: 22 August 2022 at 20:53
Dear Dyxumers,
Symmetry in photography is achieved when two halves of an image hold the same weight and give a perfect balance between two sides of a photograph.
The dictionary states “the quality of being made up of exactly similar parts facing each other or around an axis.”
In photography symmetry appears when parts of your composition mirror other parts. It is created when two halves of your scene look the same and balance each other out. Symmetry defines something being clean, proportional and balanced and will make pictures appear neat and tidy.
There are types of symmetry like horizontal, vertical and radial.
Example:
@@ green symmetry
A-580, DT 16-80mm F3.5-4.5 ZA, f/5.6, 1/1000, 16mm, ISO100.
Good light, Svjetlana
REQUIREMENTS FOR VALID ENTRIES: Each entry has to be preceded by two 'at' symbols (@@) and a title in plain text (i.e. avoid using any BB-codes) so that the automatic process we use can recognize an entry and pick it up. Exif information should also be included. Please use the following template to make sure you include all of the relevant information in a suitable format:
@@ photo title [IMG]link to the photo[/IMG] Camera: Lens: F-stop: Shutter speed: ISO: EV: Focal length: Flash: Filters and such: Film:
Entries which do not follow the above requirement will be discarded. Please remember also to get familiar with the Specific Rules section below.
This DPC will close on 22/9/2022 (earliest closing time) 21:00 Dyxum Time
Please let me remind that the winner will be awarded with the Golden Dyxum Patch
which will be sent to winner for free. It should be noted that this award was only possible because of Confusedapollo's hard work and commitment.
General rules and intent The main purpose of the Dyxum Photo Contest is to share our images in an effort to present ourselves as photographers.
All registered users are invited to participate. Each DPC is opened for approximately one month. After that a new thread is opened presenting all entrants and asking Dyxmers to vote. This voting is also opened for one month, after which all votes are counted and a winner is announced (separate "DPC winner" thread is started).
Specific rules:
- Only registered members of Dyxum.com can participate,
- The pics must be taken with A-Mount or E-mount cameras (either film or digital),
- Photos that have been winners in previous DPCs (or shots that are similar) are not eligible.
- Only two entries per competition per member are accepted. Entries can be changed freely up to the closing time. If there will be more than two photos from a given Dyxumer the last two will be accepted as his/her entries
- For each entry following information should be provided:
- Title (which must be preceded by the "@@" marker),
- Camera model,
- lens brand/model,
- In case of film cameras - type/brand/speed of a film used,
- EXIF info (not mandatory in case of film cameras): ISO speed, shutter speed, aperture, EV compensation, focal length (for zooms),
- info about any special filters/converters.
- Photos should be in an easy viewable size - no more than 1024x900 pixels (if they are bigger they will be automatically downsized by the forum app),
- No extra textures or objects that were not present during shooting should be added. Generally the stress is on photography not on post-processing, although we accept some slight modifications. If you have any doubts ask the organizer of the contest by PM.
- Images containing nudity, violence or and any kind of provocative subjects are not allowed.
Photos which flagrantly break the above rules will not be considered when selecting finalists.
Posting images Unfortunately Dyxum doesn't have sufficient web space to host images for the contest. Because of this each participant needs another hosting site for his/her images and to post them by entering the image URL in the post (surrounded by the appropriate tags). Please note that images bigger than 800 pixels (the longer side) will be resized without any further post-processing.
Copyright The photos entered remain copyrighted by the original photographer, and by entering you are giving permission for the pic/s to be used on this site only. You will be contacted about any proposed subsequent promotional use on this site of your pic/s.
Should you have any doubts or questions regarding the contest please do not hesitate to contact a member of the admin or moderator groups
Posted By: LAbernethy
Date Posted: 23 August 2022 at 05:12
@@ musing on symmetry
 Camera: Sony SLT-A99V Lens: Sony 24-70mm F2.8 ZA SSM F-stop: f/16 Shutter speed: 0.4 sec. ISO: 100 EV: 0 Focal length: 70mm Flash: yes Filters and such: no Film: no
Date Posted: 23 August 2022 at 06:23
@@Gardens, Chateau Vaux-le-Vicomte https://flic.kr/p/VvzZWt"> https://flic.kr/p/VvzZWt - Gardens, Chateau Vaux-le-Vicomte by https://www.flickr.com/photos/jozioau/ - Joe Lewit , on Flickr Camera: Sony a99ii Lens: Carl Zeiss 16-35mm f2.8 Vario-Sonnar F-stop: f/5.6 Shutter speed: 1/500 second ISO: 100 EV: 0 Focal length: 16mm Flash: - Filters and such: UV Film: -
------------- "Your first 10,000 photographs are your worst" - Henri Cartier-Bresson https://www.flickr.com/photos/jozioau/albums - My FlickrPro site
Date Posted: 29 August 2022 at 15:26
@@Blue Mosque magnificence, Istanbul https://flic.kr/p/v4ghcs"> https://flic.kr/p/v4ghcs - Blue Mosque magnificence, Istanbul by https://www.flickr.com/photos/jozioau/ - Joe Lewit , on Flickr Camera: Sony a99 Lens: Sigma 15mm f2.8 linear fisheye F-stop: f/4.0 Shutter speed: 1/60 second ISO: 1600 EV: 0 Focal length: 15mm Flash: - Filters and such: UV Film: -
Date Posted: 29 August 2022 at 20:17
@@Cow skull detail https://pegelli.smugmug.com/Other/202201/i-t9WxK8v/A"> A7ii + Panagor 28/2 (OM mount), 1/60, iso 250, f ?, -0,7 EV
@@Circular symmetry https://pegelli.smugmug.com/Other/202201/i-ZRNQ8F2/A"> A7Rii + Voigtländer 12/5.6 @ f13, 1/40, iso 125, -0,7 EV
------------- You can see the April Foolishness 2022 exhibition https://www.dyxum.com/dforum/topic141325_post1694580.html#1694580 - here Another great show of the talent we have on Dyxum
Date Posted: 29 August 2022 at 20:30
@@ Side by Side
https://basil-owen.smugmug.com/Photography/Zoo-life/i-273XD5X/A">
Camera: Sony a77ii Lens: Sony 70-400 G F-stop: f/8 Shutter speed: 1/640 second ISO: 400 EV: 0 Focal length: 280 Flash: none Filters and such: CPL Film: n/a
------------- To see is to enjoy. To see beyond is to rejoice.
Date Posted: 30 August 2022 at 06:53
@@ monastery ceiling https://flic.kr/p/2nGTg6r">
Sony ILCE-9M2 E 17-28mm F2.8 f/5.6 17.0 mm 1/30sec iso800
------------- A9II with glass from 10mm to 600mm http://www.flickr.com/photos/digiton2008 - my flickr I use google translator to translate
Date Posted: 31 August 2022 at 04:18
@@ Permanent Collection
 Camera: Sony DSLR-A850 Lens: Minolta AF 24-105mm F/3.5-4.5 F-stop: f/4 Shutter speed: 1/160sec. ISO: 1000 EV: +0.30EV Focal length: 30mm Flash: no Filters and such: no Film: n/a
Date Posted: 31 August 2022 at 09:57
@@ building X https://flic.kr/p/2nHubK2">
Sony DSLR-A900 70-200mm F2.8 G f/4.0 75.0 mm 1/640sec iso 100
Posted By: T Snijder
Date Posted: 31 August 2022 at 10:41
https://flic.kr/p/2nGC7hD"> https://flic.kr/p/2nGC7hD - abc by https://www.flickr.com/photos/181916929@N06/ - T Snijder , on Flickr
Sony ILCA-99M2 80-200mm F2.8 f/2.8 120.0 mm 1/125 sec. 200 iso no flash no filters
Date Posted: 01 September 2022 at 15:01
@@Rdam https://flic.kr/p/2nyauhn"> Sony A7iii + Sigma 2.8/45 Contemporary 1/1600 F/5 ISO160
Posted By: Harm vb
Date Posted: 04 September 2022 at 20:22
Wallpaper in the Abdij van Park in Leuven.
https://flic.kr/p/2nJCwGf">
Sony ILCE-7M4 Tamron FE 28-75mm F2.8-2.8 f/2.8 28.0 mm 1/60 4000iso no filters
------------- Harm, with A7iv+A7iii plus 14-400mm glass. https://www.flickr.com/photos/harmvanbeek/ - My Flickr
Date Posted: 05 September 2022 at 21:26
@@ Swans https://www.flickr.com/gp/147603320@N02/U2B04n3B0k"> Camera: Sony A99ii Lens: Sony 70-400mm G F-stop: f/5.6 Shutter speed: 1/3200sec. ISO: 400 EV: -- Focal length: 400mm Flash: no Filters and such: no
@@ Mosta dome https://flic.kr/p/2h9QP1J">
Camera: Sony A99ii Lens: Sony 16-35mm ZA SSM F-stop: f/13 Shutter speed: 1/30sec. ISO: 3200 EV: -- Focal length: 17mm Flash: no Filters and such: no
------------- https://www.flickr.com/photos/147603320@N02 - My Flickr https://www.instagram.com/fred_s_photography - My Instagram
Posted By: shapencolour
Date Posted: 15 September 2022 at 08:54
Sony A7R2, 24-70/4
Sony A7R2,MOG Trioplan 100/2.8 New Mk2
Sony A7R2, Sony G 24-105/4G
Date Posted: 16 September 2022 at 02:11
@@ Mokoroa Stream
 Camera: a7R Lens: SAL70-200/2.8 G SSM F-stop: f16 Shutter speed: 3.2s ISO: 50 EV: 0 Focal length: 200mm Flash: 0 Filters and such: 0 Film:0
------------- α7riii, α9, FX30- Voigtländer 15/4.5, 110/2.5 M; Zeiss Loxia- 21/2.8, 35/2, 50/2 & 85/2.4, Zeiss Batis- 85/1.8 & 135/2.8; Sony 24-105/4 G; Sigma 70/2.8 M; Tamron 150-500 f5-6.7; Sony SAL 135/2.8 STF
Posted By: Snegren
Date Posted: 16 September 2022 at 06:53
@@Symmetry in Blue https://flic.kr/p/2m9d5dy"> Camera: A7Riv Lens: Minolta AF 100mm 1:2 F-stop: f/4.516 Shutter speed: 1/800s ISO: 100 EV: 0 Focal length: 100mm Flash: 0 Filters and such: 0 Film:0
------------- “People demand freedom of speech as a compensation for the freedom of thought which they seldom use.” Søren Kierkegaard https://www.flickr.com/photos/paulemans/ - My Flickr
Date Posted: 19 September 2022 at 19:42
Sparrow Hawk
 Camera: Sony A7Riiii Lens: Sony FE100-400mm F4.5-5.6 GM OSSS +1.4X Teleconverter F-stop: F/8.0 Shutter speed: 1/125s ISO: iso250 EV: 0 Focal length: 363mm Flash: 0 Filters and such: 0 Film:0
Bald Eagle
 Camera: Sony ILCE-1 Lens: Sony FE 70-200mm F2.8 GM OSS II + 2X Teleconverter F-stop: F/8.0 Shutter speed: 1/125s ISO: iso1250 EV: 0 Focal length: 394mm Flash: 0 Filters and such: NIK Silver effex Pro Film:0
Posted By: nandbytes
Date Posted: 21 September 2022 at 00:26
@@The Louvre
Camera: Sony A7Riiii Lens: Sony FE 24-105mm F4 G OSS F-stop: F/8.0 Shutter speed: 30s ISO: 100 Focal length: 24mm
------------- https://www.flickr.com/photos/nandbytes/ - my flickr A7IV, G100
Posted By: Matt
Date Posted: 21 September 2022 at 07:57
@@The Leader and his Men https://flic.kr/p/yWm4x9"> Camera: Sony A77II Lens: Sony DT 16-80mm f/3.5-4.5 Carl Zeiss Vario-Sonnar T* F-stop: F/5.6 Shutter speed: 1/1600s ISO: 100 Focal length: 16mm
Posted By: Matt
Date Posted: 21 September 2022 at 15:02
@@Organ https://flic.kr/p/o7nNPT"> Camera: Sony A55 Lens: Tamron 18-270mm F3.5-6.3 Di II PZD F-stop: F/3.5 Shutter speed: 1/25s ISO: 400 Focal length: 18mm
Posted By: angora
Date Posted: 21 September 2022 at 18:35
@@ Snow White
Camera: A99 Lens: Minolta 135/2.8 F-stop: f6.3 Shutter speed: 1/160s ISO: 100 EV: -0.3 Focal length: 135mm Flash: no Filters and such: none
Date Posted: 21 September 2022 at 18:55
@@Religious Symmetry
Camera: Sony A99V SLT Lens: Sony 135/1,8 ZA F-stop: f3.2 Shutter speed: 1/100sec ISO: 1600 EV: 0 Focal length: 135mm Flash: no Filters and such: none
------------- My Mantra: "Comment on other's work as you would wish to have yours commented upon". Go on - it's fun!
Date Posted: 21 September 2022 at 22:10
@@ "Reflections of river Drina"
Date Posted: 21 September 2022 at 22:13
@@Autumnal Symmetry
 Camera: Sony A99V SLT Lens: Sony 135/1,8 ZA F-stop: f11.0 Shutter speed: 1/25th sec ISO: 400 EV: 0 Focal length: 135mm Flash: no Filters and such: none
Date Posted: 22 September 2022 at 18:29
@@Versailles
 Camera: Sony ILCE-5100 IR-converted Lens: Sony PZ 16-50mm F/3.5-5.6 OSS E F-stop: F/5.6 Shutter speed: 1/800 ISO: 200 EV: +1 Focal length: 45 mm Flash: --- Filters and such: ---
@@Sanssouci Paöace
 Camera: Sony ILCE-7RM2 Lens: Sony CZ 16-35mm F/4 OSS FE F-stop: F/11 Shutter speed: 1/60 ISO: 160 EV: -0.3 Focal length: 16 mm Flash: --- Filters and such: ---
------------- "Stare, pry, listen, eavesdrop. Die knowing something. You are not here long." (Walker Evans) http://www.flickr.com/photos/waldo_posth/ - http://www.flickr.com/photos/waldo_posth/
Posted By: angora
Date Posted: 22 September 2022 at 20:53
@@ beam me down (Scotty)
Camera: A580 Lens: Minolta 100-300 APO F-stop: ? Shutter speed: ? ISO: 100 EV: ? Focal length: ? Flash: no Filters and such: UV
(terribly sorry! myalbum does not show the exif anymore)
Date Posted: 22 September 2022 at 21:16
@@ "Water Lilies"
A-350, 100-300mm F4.5-5.6, f/5.6, 1/250, 280mm, ISO100.
