(Entries) DPC #306: "Made of metal"
Forum Name: Dyxum Contests
Forum Description: Dyxum photographic contests
URL: https://www.dyxum.com/dforum/forum_posts.asp?TID=141614
Printed Date: 05 October 2023 at 04:03
Topic: (Entries) DPC #306: "Made of metal"
Subject: (Entries) DPC #306: "Made of metal"
Date Posted: 28 October 2022 at 20:10
Dear Dyxumers,
A metal is a material that, when freshly prepared, polished, or fractured, shows a lustrous appearance.
A metal may be a chemical element such as iron; an alloy such as stainless steel and others.
Some of the objects made from metal are : jewellery, wires, utensils, foil paper, statues, gates, nails...
Show us anything made of metal.
Example:
@@ Harley Davidson
A-580, DT 16-80mm F3.5-4.5 ZA, f/4.5, 1/125, 80mm, ISO100.
Good light, Svjetlana
REQUIREMENTS FOR VALID ENTRIES: Each entry has to be preceded by two 'at' symbols (@@) and a title in plain text (i.e. avoid using any BB-codes) so that the automatic process we use can recognize an entry and pick it up. Exif information should also be included. Please use the following template to make sure you include all of the relevant information in a suitable format:
@@ photo title [IMG]link to the photo[/IMG] Camera: Lens: F-stop: Shutter speed: ISO: EV: Focal length: Flash: Filters and such: Film:
Entries which do not follow the above requirement will be discarded. Please remember also to get familiar with the Specific Rules section below.
This DPC will close on 28/11/2022 (earliest closing time) 21:00 Dyxum Time
Please let me remind that the winner will be awarded with the Golden Dyxum Patch
which will be sent to winner for free.
General rules and intent The main purpose of the Dyxum Photo Contest is to share our images in an effort to present ourselves as photographers.
All registered users are invited to participate. Each DPC is opened for approximately one month. After that a new thread is opened presenting all entrants and asking Dyxmers to vote. This voting is also opened for one month, after which all votes are counted and a winner is announced (separate "DPC winner" thread is started).
Specific rules:
- Only registered members of Dyxum.com can participate,
- The pics must be taken with A-Mount or E-mount cameras (either film or digital),
- Photos that have been winners in previous DPCs (or shots that are similar) are not eligible.
- Only two entries per competition per member are accepted. Entries can be changed freely up to the closing time. If there will be more than two photos from a given Dyxumer the last two will be accepted as his/her entries
- For each entry following information should be provided:
- Title (which must be preceded by the "@@" marker),
- Camera model,
- lens brand/model,
- In case of film cameras - type/brand/speed of a film used,
- EXIF info (not mandatory in case of film cameras): ISO speed, shutter speed, aperture, EV compensation, focal length (for zooms),
- info about any special filters/converters.
- Photos should be in an easy viewable size - no more than 1024x900 pixels (if they are bigger they will be automatically downsized by the forum app),
- No extra textures or objects that were not present during shooting should be added. Generally the stress is on photography not on post-processing, although we accept some slight modifications. If you have any doubts ask the organizer of the contest by PM.
- Images containing nudity, violence or and any kind of provocative subjects are not allowed.
Photos which flagrantly break the above rules will not be considered when selecting finalists.
Posting images Unfortunately Dyxum doesn't have sufficient web space to host images for the contest. Because of this each participant needs another hosting site for his/her images and to post them by entering the image URL in the post (surrounded by the appropriate tags). Please note that images bigger than 800 pixels (the longer side) will be resized without any further post-processing.
Copyright The photos entered remain copyrighted by the original photographer, and by entering you are giving permission for the pic/s to be used on this site only. You will be contacted about any proposed subsequent promotional use on this site of your pic/s.
Should you have any doubts or questions regarding the contest please do not hesitate to contact a member of the admin or moderator groups
Posted By: T Snijder
Date Posted: 29 October 2022 at 08:16
@@ Walther
https://flic.kr/p/2nVVv5A"> https://flic.kr/p/2nVVv5A - Walther by https://www.flickr.com/photos/181916929@N06/ - T Snijder , on Flickr
Camera: Sony ILCA-77M2 Lens: Sigma 105mm macro F-stop: F11 Shutter speed: 1.6 sec. ISO: 100 Flash: Led Light
Date Posted: 29 October 2022 at 09:36
@@Cast iron lighthouse staircase https://flic.kr/p/budbiu"> https://flic.kr/p/budbiu - Cast iron staircase, Split Point lighthouse, Airey's Inlet by https://www.flickr.com/photos/jozioau/ - Joe Lewit , on Flickr Camera: a900 Lens: Sigma 15mm f2.8 Linear Fisheye F-stop: F 2.8 Shutter speed: 1/15 second ISO: 200 Flash: - EV compensation: - Filters: -
------------- "Your first 10,000 photographs are your worst" - Henri Cartier-Bresson https://www.flickr.com/photos/jozioau/albums - My FlickrPro site
Date Posted: 29 October 2022 at 09:44
@@19thC carriage clock https://flic.kr/p/2iPMBAJ"> https://flic.kr/p/2iPMBAJ - 19thC carriage clock, half left by https://www.flickr.com/photos/jozioau/ - Joe Lewit , on Flickr Camera: a99ii Lens: Carl Zeiss 135mm f1.8 Sonnar F-stop: F 1.8 Shutter speed: 1/60 second ISO: 5000 Flash: - EV compensation: - Filters: UV
Posted By: Dena
Date Posted: 29 October 2022 at 23:19
@@Iron Horse
 Camera: a77ii Lens: Minolta 80-200mm f2.8, white version F-stop: F8 Shutter speed: 1/250 second ISO: 200 Focal Length: 80mm Flash: none EV compensation: nA Filters: none
Posted By: Jadom
Date Posted: 01 November 2022 at 20:08
Little Mermaid: https://flic.kr/p/2nK9G7u"> https://flic.kr/p/2nK9G7u - _DSC14378 by [url=https://www.flickr.com/photos/189006412@N03/]
Camera: Sony ILCE A7M2 Lens: Sony/Zeiss FE 16-35mm, f4, ZA OSS F-stop: 4.5 Shutter speed: 1/60 ISO: 100 EV: -0.3 Focal length: 32mm Flash: not fired Filter: none
------------- Jack.SigmaDP1x,DP2M,SonyA7M2,Min: MC35F2.8, AF50F1.7, 70-210F, SL16-35F4, KironKine 80-200F4Macro, Promaster MC28F2.8, Rokinon 85f1.4, Samyang 14F2.8, Tamron: SP AF 28-75F2.8XR Di LD, 70-300 F4-5.6Di
Posted By: Snegren
Date Posted: 02 November 2022 at 18:51
@@On the edge https://www.flickr.com/photos/paulemans/52473210028/"> Camera Model: ILCE-7M3 Lens: MINOLTA V MACRO LENS 50mm f/3.5 on MonsterAdapter LA-VE2 auto focus adapter Focal Length: 50 mm Aperture: f/5.6 EV: 0 Exposure Time: 1 ISO: 100
------------- “People demand freedom of speech as a compensation for the freedom of thought which they seldom use.” Søren Kierkegaard https://www.flickr.com/photos/paulemans/ - My Flickr
Date Posted: 04 November 2022 at 12:43
@@Torch
https://flic.kr/p/2nW6jtw"> https://flic.kr/p/2nW6jtw - Torch by https://www.flickr.com/photos/181916929@N06/ - T Snijder , on Flickr
Camera: Sony ILCA-99M2 Lens: 105mm F2.8 F-stop: f/9 Shutter speed: 1,3 sec. ISO: 100 EV: - Focal length: 105.0 mm
Date Posted: 06 November 2022 at 20:00
@@Metal lips
Camera: Sony ILCA-99M2 Lens: Sony 70-200mm F2.8 G SSM F-stop: f/2.8 Shutter speed: 1/200 sec. ISO: 320 EV: - Focal length: 200mm
------------- Sony a7R4, a6400. E, A and MD lenses.
Date Posted: 07 November 2022 at 14:59
@@ Old keychain (of a deported family, trying to hold on to their property) https://pegelli.smugmug.com/Other/202209/i-2DKk3jq/A"> A7ii + Tamron 28-200 Di III RXD, 52 mm, 1/60 sec, f 5, iso 5000, -0,3 EV
@@ Iron swan, made by my grandfather https://pegelli.smugmug.com/Other/202002/i-rzgqgzW/A"> A7ii + M-Summicron 50/2 DR, 1/5 sec, f ?, iso 100, +0,7 EV
------------- You can see the April Foolishness 2023 exhibition https://www.dyxum.com/dforum/april-foolishness-2023-the-exhibition_topic142439.html - here Another great show of the talent we have on Dyxum
Posted By: Harm vb
Date Posted: 10 November 2022 at 10:39
@@Kitchen Gear
https://flic.kr/p/2nYpNvu">
Sony ILCE-7M4 | FE 90mm F2.8 Macro G OSS | f/11.0 | 90.0 mm | 4s | 250iso
------------- Harm, with A7iv+A7iii plus 12-400mm glass. https://www.flickr.com/photos/harmvanbeek/ - My Flickr
Date Posted: 10 November 2022 at 11:04
@@The Metal Lovers
 Camera: Sony A700 Lens: Sony SAL18250 DT 18-250mm F/3.5-6.3 Focal length: 180 mm F-stop: f/8.0 Shutter speed: 1/60th sec. ISO: 250 EV: 0
------------- My Mantra: "Comment on other's work as you would wish to have yours commented upon". Go on - it's fun!
Date Posted: 10 November 2022 at 11:30
@@Metal Patterns
 Camera: Sony SLT A99V Lens: Sony 135/1.8 ZA Focal length: 135 mm F-stop: f/3.2 Shutter speed: 1/13th sec. ISO: 1600 EV:
Posted By: Robbie
Date Posted: 10 November 2022 at 15:30
@@Turbine
 Camera: Sony A7 IV Lens: Min. 35 mm F2 via Sony La-EA 5 Focal length: 35 mm F-stop: f/2.5 Shutter speed: 1/40 sec. ISO: 800 EV: - 3/10
------------- https://www.flickr.com/photos/67726991@N08/ - My Flickr
Posted By: Matt
Date Posted: 10 November 2022 at 15:57
@@Canadian Silver https://flic.kr/p/c3AjUs"> Camera: Sony A55 Lens: Sony DT 35mm F1.8 SAM Focal length: 35 mm F-stop: f/16.0 Shutter speed: 2 sec. ISO: 100 EV: 0
@@Mechanics https://flic.kr/p/Ku3Jvu"> Camera: Sony A77II Lens: Sony DT 35mm F1.8 SAM Focal length: 35 mm F-stop: f/2.8 Shutter speed: 1/15 sec. ISO: 800 EV: 0
Posted By: Robbie
Date Posted: 16 November 2022 at 16:06
@@Gear Wheels
 Camera: Sony A7 IV Lens: Sony FE 20 mm F1.8 G Focal length: 20 mm F-stop: f/5.6 Shutter speed: 1/30 sec. ISO: 6400 EV: ± 0 EV
Date Posted: 16 November 2022 at 17:47
@@SpeelseSpreeuwen https://flic.kr/p/2nZDswQ"> A7iii + 35GM f/4 1/500 ISO400
@@ErasmusBridge https://flic.kr/p/2o2uuRK"> A7iii + Sigma 2.8/45 Contemporary (14 image stitch) f/6.3 1/500 ISO640
Date Posted: 22 November 2022 at 19:32
@@ Fixed
A-580, DT 16-50mm F2.8 SSM, f/4.5, 1/40, 50mm, ISO400.
@@ Calibration weights
A-580, DT 16-50mm F2.8 SSM, f/3.5, 1/60, 16mm, ISO800.
Posted By: LAbernethy
Date Posted: 23 November 2022 at 02:54
@@ Pick'n an' a Slide'n
 Camera: Sony DSLR-A700 Lens: SAL50M28 F-stop: f/5.0 Shutter speed: 1.3sec. ISO: 100 EV: -0.7 Focal length: 50mm Flash: no Filters and such: no Film: no
@@Tea with Alice
 Camera: Sony SLT-A99V Lens: SAL100M28 F-stop: f/7,1 Shutter speed: 0.8sec. ISO: 100 EV: +0 Focal length: 100mm Flash: yes Filters and such: no Film: no
Posted By: alanfrombangor
Date Posted: 24 November 2022 at 10:50
@@ Keyring
 Camera: A77 Lens: Tamron 90/2.8 F-stop: 2.8 Shutter speed: 1/40 ISO: 400 EV: 0 Focal length: 90
@@ Litter to be recycled
 Camera: A77 Lens: Sony Zeiss 16-80DT F-stop: 3.5 Shutter speed: 1/30 ISO: 800 EV: 0 Focal length: 16
Date Posted: 25 November 2022 at 13:41
@@ thoughts
 A9 & Sony 24-105 F4 @ 89mm 1/160sec F4 iso200 -0.7ev
Date Posted: 26 November 2022 at 20:58
@@ From before the age of plastic fantastic https://flic.kr/p/22osuvW">
Camera: A99 Lens: Aus Jena 2.8/50mm F-stop: 2.8 Shutter speed: 1/3 ISO: 100 EV: 0 Focal length: 50mm Flash: No Filters and such: None
@@ Tin soldier https://flic.kr/p/KqfLqf">
Camera: A99 Lens: Sony 2.8/70-200G F-stop: 3.2 Shutter speed: 1/160 ISO: 200 EV: 0 Focal length: 150mm Flash: No Filters and such: None
------------- https://www.flickr.com/photos/147603320@N02 - My Flickr https://www.instagram.com/fred_s_photography - My Instagram
Posted By: angora
Date Posted: 28 November 2022 at 20:38
@@ Christine...
Camera: A99 Lens: Minolta 28-135 F-stop: f7 Shutter speed: 1/50s ISO: 100 EV: 0 Focal length: 35mm Flash: No Filters and such: UV
Date Posted: 28 November 2022 at 21:09
@@ OH-LCH
 Camera: Sony α7R IV Lens: Sony FE 5.6-6.3/200-600 G OSS + 1.4× TC F-stop: f/10 Shutter speed: 1/800 s ISO: 640 EV: -0.3 Focal length: 280 mm Flash: n/a Filters and such: none
------------- http://hezu.1g.fi/ - Galerie Hezu
Posted By: floydbloke
Date Posted: 29 November 2022 at 00:25
@@Timing Wheel https://flic.kr/p/2kQJ1yw"> Camera: A6600 Lens: Tamron E 28-75mm F2.8-2.8 F-stop: 4.0 Shutter speed: 1/125 ISO: 250 EV: - Focal length: 75mm Flash: on Filters and such: - Film: -
Posted By: MinoltaMad
Date Posted: 29 November 2022 at 04:42
@@ Western Line
Sony a99M2 Sony CZ 24-70mm f2.8 SSM ZA ISO 3200 24mm f8 1/5sec handheld no EV or flash or filters
Date Posted: 29 November 2022 at 04:45
@@ Convergence
Sony a99M2 Sony CZ 24-70mm f2.8 SSM ZA ISO 1600 24mm f5.6 1/40 sec no EV or flash or filters
