Cypress Trees (two images added 24 Nov.)
Forum Name: Open Views
Forum Description: Showcase your work and give feedback on other members' work
URL: https://www.dyxum.com/dforum/forum_posts.asp?TID=141688
Printed Date: 26 November 2022 at 15:52
Topic: Cypress Trees (two images added 24 Nov.)
Posted By: Roger Rex
Subject: Cypress Trees (two images added 24 Nov.)
Date Posted: 21 November 2022 at 11:52
I captured these images in two sessions in quite varying lighting and weather conditions. Thus, I chose a high key approach to provide uniformity to the series, uniformity in appearance being an important characteristic to me when presenting a series. Comments and criticism welcome.
https://hosting.photobucket.com/images/b84/rex50plus/Char2205v2-72.jpg?width=180&height=180&fit=bounds">
https://hosting.photobucket.com/images/b84/rex50plus/Char2201v7-72.jpg?width=180&height=180&fit=bounds">
https://hosting.photobucket.com/images/b84/rex50plus/Char2217v5-72.jpg?width=180&height=180&fit=bounds">
https://hosting.photobucket.com/images/b84/rex50plus/Char2202v2-72.jpg?width=180&height=180&fit=bounds">
https://hosting.photobucket.com/images/b84/rex50plus/Char2203v5-72.jpg?width=180&height=180&fit=bounds">
Hatred corrodes the container it is carried in. http://rogerrex.zenfolio.com/
Date Posted: 22 November 2022 at 06:09
The first two are breathtakingly beautiful, although #2 wins. While i like the viewpoint in #3, the cutoff tree on the right somehow bothers a tad, but the strong point is the tree in the middle which takes you into the frame. The last one is a bit too empty for my taste, but it fits wonderful in the series. Thanks master Roger
Respect Observe Capture Enjoy
Posted By: Jadom
Date Posted: 22 November 2022 at 07:34
Very interesting approach, Master Roger. #4 for me. TFS
Jack.SigmaDP1x,DP2M,SonyA7M2,Min: MC35F2.8, AF50F1.7, 70-210F, SL16-35F4, KironKine 80-200F4Macro, Promaster MC28F2.8, Rokinon 85f1.4, Samyang 14F2.8, Tamron: SP AF 28-75F2.8XR Di LD, 70-300 F4-5.6Di
Date Posted: 23 November 2022 at 05:50
Another vote for #2 - overall the best composition IMO - and acceptable contrast. I like #3 a lot, for me in terms of composition it is clearly better than #4 (the water lacks smoothness), but there are some deficiencies: e.g., it lacks sharpness and contrast. #2 stands out, I think, because it has the best contrast in the series (still improvable). Processing for high key may spoil contrast.
Generally for me the images are (in different degrees) a bit too mushy.
"Stare, pry, listen, eavesdrop. Die knowing something. You are not here long." (Walker Evans)    http://www.flickr.com/photos/waldo_posth/ - http://www.flickr.com/photos/waldo_posth/
Posted By: MinoltaMad
Date Posted: 24 November 2022 at 05:15
Wonderful idea and execution. I like #2 the best and then #1. You could try a more letterbox type crop on #1 and #2 with some of the sky removed?
Date Posted: 24 November 2022 at 15:16
Thanks all for the comments.
waldo-posth - "lacks sharpness and contrast" - true of all of them. Lack of sharpness due two one of two factors - wind (gusts up to 40 mph) and/or poor focusing on my part. Contrast - yes, all are high key and for my taste in this situation I like lower contrast. There certainly is a case for high contrast, maybe even very high contrast, to create more of a graphic design look and feel.
MinoltaMad - Letterbox image below that shows the entire scene. I tend to prefer the letterbox or panorama format if the scene is already extremely wide.
https://hosting.photobucket.com/images/b84/rex50plus/Char2218v3-72.jpg?width=180&height=180&fit=bounds">
Date Posted: 24 November 2022 at 15:56
And one in color.
7
https://hosting.photobucket.com/images/b84/rex50plus/Char2219v2-72.jpg?width=180&height=180&fit=bounds">
Date Posted: 24 November 2022 at 21:15
Now #6 has become my favorite. The panorama format really adds to the subject and there is an additional element which enhances the composition: the clouds.
#7 could rather be taken in a desert, during a sandstorm - but fascinating to see.
TFS, Roger - great work!
Date Posted: 25 November 2022 at 06:29
Thanks for indulging me with #6 - fantastic. Interesting colour one as well!
Date Posted: 25 November 2022 at 06:56
Fully agree, the image is a bit more "alive". One thing about the earlier images; the lack of sharpness and contrast was not a problem for me, it suited the images imo.
