200mm 2.8 APO
Forum Name: A-mount lenses
Forum Description: For A-mount lens discussions
URL: https://www.dyxum.com/dforum/forum_posts.asp?TID=144185
Printed Date: 22 March 2025 at 19:02
Topic: 200mm 2.8 APO
Posted By: johnbscot
Subject: 200mm 2.8 APO
Date Posted: 02 April 2024 at 12:40
HI, I have damaged the lens hood of the Minolta 200mm f2.8 APO lens. Does anyone know how I can remove the lens hood?
Date Posted: 02 April 2024 at 19:07
The integral lens hood of the MinAF 200/2.8 cannot be removed that easily and especially from the front, instead you have to dismantle the lens starting from the back side by removing lens mount and then bit by bit. For sure https://www.dyxum.com/dforum/uploads/717/Minolta_AF200f28APO_Tele.zip - this will help
------------- /Michael
Posted By: dxqcanada
Date Posted: 03 April 2024 at 00:20
I did it, not that difficult.
https://oldcam.wordpress.com/tag/maxxum-af-200mm-f-2-8-apo/ - https://oldcam.wordpress.com/tag/maxxum-af-200mm-f-2-8-apo/
------------- Sony A77mII, A57, Nex-6 | Minolta Maxxum 9000, Autocord . http://oldcam.wordpress.com - http://oldcam.wordpress.com
Posted By: ffrolvaag
Date Posted: 03 April 2024 at 03:02
https://oldcam.wordpress.com/tag/maxxum-af-200mm-f-2-8-apo/ - https://oldcam.wordpress.com/tag/maxxum-af-200mm-f-2-8-apo/ |
Me too, but it has been a while since I tore mine apart. The tear down is comparable to other prime lenses, and relatively easy. The main difference (and challenge) is the wires that are mentioned and shown in the photos in the hyperlinked website. I recall having to de-solder and re-solder them, but it seems that they were able to work around the need to do so.
------------- Franz
a99ii, Hassy HV, a900, 1200 (w/MFC-1000), 3x converted f1.2 (Rokkor 58, Nikon 50 ais, and Pentax 50), and assorted lenses from 8mm f4 - 1000mm f8
Date Posted: 03 April 2024 at 10:56
Many thanks for the link that you provided. Very helpful.
Date Posted: 04 April 2024 at 16:53
The information helped to correct the damage to my 200mm AF 2.8 apo lens. I am so pleased with the result... many thanks again!!!
Date Posted: 04 April 2024 at 16:55
Thank you all, a success!
Date Posted: 04 April 2024 at 22:35
